2005 2500 hd ?
What seats do you have in your 05 now?
the seats look exactly like the ones for sale on ebay, color and everything. but there listed as 2001-2003 seats. i asked the question but havent gotten any reply yet. the freight would be outragous! but we happen to be only 60 miles apart. so i would just go pick them up. like i say the look exactly the same. i figured if a had to the tracks would probably interchange anyway.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
