4.3L V6 Engine VIN W,X
To anyone with same problem,
I own a 95 Chevy s-10 w/ 4.3L. I'm wondering if anyone has came across the same problem as I. Rattle noise or knock occurring in the 2000-2500rpm range, under a moderate to heavy load, with warmed-up engine. It sounds like upper end so I proceeded and replaced the lifters and the problem is still there. If anyone has any suggestions it would be greatly apprecieated.
Thanks,
Mark
        Thanks,
        Mark
my 93 had a cracked piston, same symtoms you describe.
it would disaapear if I shorted out the spark plug on the offending cylinder, that is how I figured out which cylinder had the problem.
after I took it apart I could see the source of the problem but before dissassembly I only knew it was something in one particular cylinder.
hopefully its something simpler on your truck, have you pulled th oil pan and checked the bearings?
        Thanks,
        Mark
Kick,
No I didn't drop the oil pan yet. It sucks cause the front diff. is in the way. But I wodner if I had a spun cranck bearing if it would give me the same noise???
IF YOU SPUN A BEARING ENGINE PROBABLY WOULD HAVE LOCKED UP.
A LOOSE BEARING WILL MAKE NOISE
, GENERALLY A KNOCK OR A THUDDING SOUND.
THESE NOISES CAN BE ISOLATED BY DISCONNECTING SPARK PLUGS, ONE AT A TIME, ESPECIALLY IN REFERENCE TO ROD OR PISTON NOISES.
IS ENGINE RUNNING OK OTHER THAN THE NOISE?
TRY LISTENING TO IT WITH A STETHOSCOPE JUST TO PINPOINT THE AREA THE NOISE IS COMING FROM?
Kick,
The motor runs fine. There is no miss or anything. Someone had mentioned to me there's something called a balancer shaft in these motors. And soemtimes they create a vibration and that can be the culprit. I noticed the shaft when I replaced the lifters & didn';t see no scoring or anything on the shaft. The play in the shaft seemed to minimal. Not sure where else to look. Like you said, pull of 1 spark plug at a time?? Don't know
I have this same rattle...sounds almost like a Diesil knock, or a "clank"
Cracked flywheel...is a term ive heard a few times...dont really know why that would create a "clatter"
Kick,
theres a lot of things that cause noise.
mine ran fine with the cracked piston. mine dont have the balance shaft .
like somebody else sed, flywheel cracked. yep that can cause it.
bad motor mounts. bad harmonic balancer etc...
    mighty K20
    mighty K20
  • Who's Online   6 Members, 0 Anonymous, 646 Guests (See full list)
