vehicle weight
The weight should be on your door sticker (on the drivers side door, inside the jamb).
Gears...There's a sticker in your glove box with the "RPO" codes for your specific truck listed. There is a link on the left of the page that will lead you to the RPO guide...listing what each 3 character code represents.
Heck...I'll just paste them here.
1998 Regular Production Options (RPOs)...
Just the axle ones:
GK9 Rear Axle: 4.63 Ratio
GTY Axle Wide Track
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
G80 Rear Axle: Positraction
HC4 Rear Axle: 4.56 Ratio
HC7 Rear Axle: 5.13 Ratio
And here's aaaaalllll the rest of the RPO Codes for you :)
RPO Descriptions
AE7 60/40 Front Split Bench Seat, Driver, Passenger Easy Entry
AG2 Seat Adjuster: Power, 6-way, Passenger
AG9 Seat Adjuster: Power, 6-way, Driver
AJ1 Windows: Deep Tint
AJ3 Restraint: Front Seat, Driver Inflatable
AL3 Restraint: Front Seat, Driver Inflatable, Delete
AM7 Seat, Rear Folding
APC Provisions, Front Bucket Seating
APD Provisions, Front Bench Seating
APR Sales Incentive, 2500 Work Truck
AS3 Seat, Rear Suburban
ATZ Seat, Rear Delete
AT5 Seat, Center
AU0 Lock Control: Remote Entry
AU3 Locks, Power Door
AU6 Electric End Gate Lock Release
A20 Window: Rear Quarter Swing Out
A21 Window: Non Encapsulated Glass
A28 Window: Rear, Full Width, Sliding
A31 Windows: Power
A50 Seat, Front Bucket
A52 Seat, Front Bench
A95 Seat: Front Bucket, High Back, Pass and Driver Reclining
BAG Parts Package, Export
BG9 Floor Covering, Rubber
BNP Molding Wheel Opening Delete
BVE Steps, Running Board
BYP Sales, Sport Equipment Package
BZY Liner, Pickup Box
B30 Floor Covering, Carpet
B32 Auxiliary Floor Covering, Front Floor Mats
B33 Auxiliary Floor Covering, Rear Floor Mats
B34 Carpeted Front Floor Mats
B35 Carpeted Rear Floor Mats
B37 Floor Covering, Auxiliary Front and Rear
B39 Floor Covering, Carpeted Floor Mat
B4L Label Price, Refer Geographic Chart
B71 Molding, Wheel Opening Colored
B85 Molding, Body Side, Exterior
B96 Molding, Wheel Opening
CMD Plant Code, Flint, MI
C25 Wiper System, Rear Window
C3F 7700 Lbs. GVW Rating
C36 Auxiliary Heater
C49 Rear Window Defogger
C5B 15000 Lbs. GVW Rating
C5I 8050 Lbs. GVW Rating
C5M 6100 Lbs. GVW Rating
C5P 6250 Lbs. GVW Rating
C5Q 6300 Lbs. GVW Rating
C5S 6600 Lbs. GVW Rating
C5U 6800 Lbs. GVW Rating
C5Z 7200 Lbs. GVW Rating
C6P 8600 Lbs. GVW Rating
C6U 9000 Lbs. GVW Rating
C6W 9200 Lbs. GVW Rating
C6Y 9600 Lbs. GVW Rating
C60 HVAC System, Front Air Conditioning
C69 HVAC System, Rear Air Conditioning
C7A 10000 Lbs. GVW Rating
C7E 11000 Lbs. GVW Rating
C7I 6450 Lbs. GVW Rating
C7L 12000 Lbs. GVW Rating
DD0 Mirror, Outside, LH and RH, Electric, Heated, Electrochromic
DD7 Mirror: I/S, Rearview Light Sensitive, Compass
DE2 Mirror: O/S, LH & RH, Folding, Painted
DF2 Mirror: O/S, LH & RH, Camper Style, Stainless Steel
DF5 Mirror: I/S, Rearview, Electrochromic, Compass and Outside Temperature
DG5 Mirror: O/S, LH & RH, Large Stainless Steel
DK6 Console: Roof, Interior
DR1 Mirror: O/S, LH & RH, Manual Control
D44 Mirror: Outside, Painted
D45 Mirror: Outside, Stainless Steel
D48 Mirror: Outside, Remote Control, Electric
D55 Console, Front Compartment, Floor
EF1 Bumper Provisions, Rear, Delete
EXP Export, International Sales
E24 Door, Rear Side Hinged
E55 Body Equipment End Gate
E62 Body Equipment, Stepside Pickup Box
E63 Body Equipment, Fleetside Pickup Box
FE9 Certification: Emission, Federal
FG5 Shock Absorbers: Front & Rear, Gas, Delco/Bilstein, 46MM
FW1 Plant Code, Fort Wayne, IN, GM NATG
F44 Chassis, Heavy Duty
F48 Chassis, Manual Select Dampening
F51 Shock Absorbers, Front and Rear, Heavy Duty
F60 Spring, Front, Heavy Duty
F61 Stabilizer Shaft: Rear
GAM Vehicle Government
GTY Axle Wide Track
JAN Plant Code, Janesville, WI, GM NATG
JB5 Brake System: Power, Front Disc, Rear Drum, 6400 Lbs.
JB6 Brake System: Power, Front Disc, Rear Drum, 7200 Lbs.
JB7 Brake System: Power, Front Disc, Rear Drum, 8400 Lbs.
JB8 Brake System: Power, Front Disc, Rear Drum, 10000 Lbs.
JD5 Brake System: Dual Power, Front Disc, Rear Drum, 6400 Lbs.
JD6 Brake System: Hydraulic Power, Front Disc, Rear Drum, 7200 Lbs.
JD7 Brake System: Hydraulic Power, Front Disc, Rear Drum, 8400 Lbs.
JF9 Brake System: Hydraulic Power, Four Wheel Disc
KA1 Heated Seats, DR/PS, High Back Buckets w/Leather
KC4 Cooling System, Engine Oil
KG9 Generator, 140 Amp
KL5 Modification Engine, Natural Gas
KL6 Provisions, Natural Gas
KNP Transmission, Heavy Duty Cooling System
KW2 Generator, 124 Amp
KXB Dual Generator, 100 Amp
K02 Fan: Radiator Booster
K05 Heater: Engine Block
K34 Cruise Control: Automatic, Electronic
K47 Air Cleaner, High Capacity
K60 Generator: 100 Ampere
K68 Generator: 105 Ampere
L29 Engine: 7.4 Liter V8, MFI
L30 Engine: 5.0 Liter V8, CPI
L31 Engine: 5.7 Liter V8, CPI
L35 Engine: 4.3 Liter V6, CPI
L56 Engine Diesel: 6.5 Liter V8, Turbo
L65 Engine Diesel: 6.5 Liter V8, Turbo
MG5 Transmission: Manual 5 Speed, New Venture Gear
MSL Plant Code, Silao, Mexico
MT1 Transmission: 4L80-E, 4-Speed Automatic, Electronic
MW3 Transmission: Manual 5 Speed, New Venture Gear
M30 Transmission: 4L60-E, 4-Speed Automatic, Electronic
M50 Transmission: Manual 5 Speed, New Venture Gear
NA1 Emission System: GVW Less than 8500 lbs
NA4 Emission System: GVW Above 8500 lbs
NA5 Emission System: Federal, Tier 0
NB2 Emission System: California, Tier 0
NB6 Emission System: California, Tier 1
NB8 Emission Override: California System
NC1 Emission System: California, LEV
NC7 Emission Override: Federal System
NF2 Emission System: Federal, Tier 1
NG1 Certification Emission, Geographically Restricted Registration
NM8 Leaded Fuel System Compatible
NN8 Emission Override Unleaded Fuel, Export
NP1 Transfer Case, Electronic Shift, Two Speed
NP5 Steering Wheel: Leather Wrapped
NQZ Fuel Tank, Auxiliary, Rear Mounted, 18 Gallon, Delete
NRQ Exhaust Close Coupled
NY1 Shield, Fuel Tank
NZZ Sales Package, Skid Plate, Off Road Sport
N33 Steering Column: Tilt Type
N83 Wheel: 15 x 7, Chrome Styled
N90 Wheel: 15 x 7, Aluminum Cast, 4.75 Inch Bolt Circle
OSG Plant Code, Oshawa, Ontario, GM of Canada
PF4 Wheel: 16 x 7, Aluminum Cast
PO6 Wheel, Trim Discs
QBN Tire: All, LT245/75R16/C BW R/PE ST TBL OOR
QBX Tire: All, LT245/75R16/C WOL R/PE ST TBL OOR
QFL Tire: All, P235/75R15 BW R/PE ST TL ALS 105S
QFN Tire: All, P235/75R15 WL R/PE ST TL ALS 105S
QGA Tire: All, P245/75/R16 BW R/PE ST TL ALS 109S
QGB Tire: All, P245/75/R16 WOL R/PE ST TL ALS 109S
QGC Tire: All, P265/75/R16 BW R/PE ST TL ALS 114S
QGD Tire: All, P265/75/R16 WOL R/PE ST TL ALS 114S
QHA Tire: All, P235/75/R15/X BW R/PE ST TL ALS
QIW Tire: All, P245/75/R16 BL R/PE ST TL OOR
QIZ Tire: All, P245/75/R16 BL R/PE ST TL ALS
Q4B GVW Rating 6200 lbs.
RHD Right Hand Drive
RSA Restraint: Front Seat, 208, Auto, Passive
RSB Restraint: Front Seat, 208, Auto, Manual, Active
R04 Wheel, Single Rear
R05 Wheel, Dual Rear
TP2 Battery Auxiliary, Camper
TL1 Grille: Special
T62 Lighting, Daytime Running, Delete
T85 Headlamps: LH Rule of Road, E Mark
UC2 Speedometer: Instrument, Kilometers & Miles, Kilometer Odometer, Positive Bias
UD4 Alarm: Vehicle Speed, 120 K/H
UG1 Homelink™ 3-Channel Transmitter
UK1 Radio, Frequencies, Japanese
UL0 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse Cassette, Music Search
UL2 Radio, Frequencies, European
UL5 Radio: Delete
UM6 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse Cassette, Clock, ETR
UM7 Radio: AM/FM Stereo, Seek/Scan, Clock, ETR
UN0 Radio: AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone
UP0 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse, Music Search, Cassette, Compact Disc Player, Auto Tone
UQ3 Speaker System, Performance Enhanced Radio
UQ5 Speaker System 4, Dual Front Door Mounted, Dual Extended Range, Quarter Mounted
UW3 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse, Music Search
UY1 Wiring Provisions, Camper
U01 Roof Marker Lamp, Five
U19 Speedometer Inst, Kilo and Miles
VB1 Label Shipping, Japan
VB3 Bumper, Rear Step, Chrome, Impact Strip
VC0 Vehicle Label, Noise Control Information
VC4 Label Price/Fuel Econ, Puerto Rico
VC5 Label Shipping, Except for US, US Possessions, Or Japan
VC7 Label Price/Fuel Econ, Guam
VG3 Bumper, Front Impact Strip
VG8 Vehicle Label, Notice to Buyer
VK3 License Plate, Front Mounting Package
VK5 Seat: Temporary, For Shipping
VPH Vehicle Preparation Overseas Delivery
VL3 Label: Mirror, O/S Warning
VR4 Trailer Hitch: Weight Distributing Platform
VR6 Hook: Tie Down
VS7 Vehicle Non-Saleable
VYU Provisions, Snow Plow Prep
V10 Provisions: Cold Climate
V22 Grille Chrome, Radiator
V27 Guards, Front Bumper
V43 Bumper, Rear Step, Painted
V54 Luggage Carrier, Roof, Painted
V60 Vehicle Statement Gulf States Organization, Incomplete Vehicle
V73 Vehicle Statement US/Canada
V76 Tow Hook
V78 Vehicle Statement Delete
V87 Vehicle Statement Gulf States Organization
V98 Factory Delivery Processing
WD1 Identification Pilot Vehicle
W99 Equipment Misc Equip For Venez
XBN Tire: Front, LT245/75/R16/C BL R/PE ST TBL OOR
XBX Tire: Front, LT245/75/R16/C WOL R/PE ST TBL OOR
XFL Tire: Front, P235/75/R15 ST TL ALS B/W
XFN Tire: Front, P235/75/R15/N WL R/PE ST TL ALS 105S
XGA Tire: Front, P245/75/R16 BW R/PE ST TL AT 109S
XGB Tire: Front, P245/75/R16 WOL R/PE ST TL AT 109S
XGC Tire: Front, P265/75/R16 BW R/PE ST TL AT 114S
XGD Tire: Front, P265/75/R16 WOL R/PE ST TL AT 114S
XGK Tire: Front, LT245/75/R16 BL R/PE ST OOR
XHA Tire: Front, P235/75/R15X BL R/PE ST TL ALS
XHE Tire: Front, LT235/75/R16C BL R/PE ST ALS
XHH Tire: Front, LT245/75/R16E BL R/PE ST ALS
XHM Tire: Front, P235/75/R15 WOL R/PE ST TL ALS 108S (X/LOAD)
XHP Tire: Front, LT225/75/R16D BL R/PE ST TL ALS
XHR Tire: Front, LT225/75/R16D BL R/PE ST TL OOR
XTN Tire: Front, 225/70R9.5F BW R/ST ST TL HWY
XYK Tire: Front, LT215/85/R16D BL R/PE ST TL OOR
XYK Tire: Front, LT215/85/R16D BL R/PE ST TL HWY
X81 Sales Incentive Price Leader
X88 Conversion Name Plate -- CHEVROLET
YA7 Assembly Line Emission Test, California
YA9 Axle, 3400 lbs
YBN Tire: Rear, LT245/75R16C BL R/PE ST TBL OOR
YBX Tire: Rear, LT245/75R16C WOL R/PE ST TBL OOR
YD3 Front Axle For Scheduling GVW Plate
YD6 Rear Spring, Base Equipment
YD7 Axle for Scheduling GVW Plate, Used with R05
YE9 Convenience Package Comfort and Decor Level #3
YFL Tire: Rear, P235/75R15 BW R/PE ST TL ALS
YFN Tire: Rear, P235/75R15N RWL R/PE ST TL ALS 105S
YF2 Sales Package, Ambulance Upfitter
YF4 Vehicle Engineering, Hold Order
YF5 California Emission Certificate
YF7 Sales Package, Recreational Vehicle Upfitter
YGA Tire: Rear, P245/75R16 BW R/PE ST TL AT 109S
YGB Tire: Rear, P245/75R16 WOL R/PE ST TL AT 109S
YGC Tire: Rear, P265/75R16 BW R/PE ST TL AT 114S
YGD Tire: Rear, P265/75R16 WOL R/PE ST TL AT 114S
YGK Tire: Rear, P245/75R16E BL R/PE ST OOR (9591214)
YG4 Optional Seats Not Desired
YHA Tire: Rear, P235/75R15X BL R/PE ST TL ALS
YHH Tire: Rear, P245/75R16E BL R/PE ST ALS
YHM Tire: Rear, P235/75R15 WOL R/PE ST TL ALS 108S (X/LOAD)
YHP Tire: Rear, LT225/75R16D BL R/PE ST TL ALS
YHR Tire: Rear, LT225/75R16D BL R/PE ST TL OOR
YTN Tire: Rear, LT225/70R19.5 BW R/ST ST TL HWY
YYK Tire: Rear, LT215/85R16D BL R/PE ST TL HWY
YYL Tire: Rear, LT215/85R16D BL R/PE ST TL OOR
Y91 Sales Package, Luxury (GMT 425)
ZA6 Package Price Leader, Canadian
ZA7 Package Value Leader, Canadian
ZBN Tire: Spare LT245/75R16C BL R/PE ST TBLE OOR
ZBX Tire: Spare LT245/75R16C WOL R/PE ST TBLE OOR
ZFL Tire: Spare P235/75R15 BW R/PE ST TL ALS 105S
ZFN Tire: Spare P235/75R15N RWL R/PE ST TL ALS 105S
ZGA Tire: Spare P245/75R16 BW R/PE ST TL ALS 109S
ZGB Tire: Spare P245/75R16 WOL R/PE ST TL AT 109S
ZGC Tire: Spare P265/75R16 BW R/PE ST TL AT 114S
ZGD Tire: Spare P265/75R16 WOL R/PE ST TL AT 114S
ZGK Tire: Spare LT245/75R16E BL R/PE ST OOR
ZHA Tire: Spare P235/75R15X BW R/PE ST TL ALS
ZHH Tire: Spare LT245/75R16E BL R/PE ST ALS
ZHM Tire: Spare P235/75R15 WOL R/PE ST TL ALS 108S (X/LOAD)
ZHP Tire: Spare LT225/75R16D BL R/PE ST TL ALS
ZHR Tire: Spare LT225/75R16D BL R/PE ST TL OOR
ZM9 Sales Package Comfort and Convenience (Utility/Suburban Feature Package)
ZP6 Sales Package Combination, Rear Window Wiper/Rear Window Defogger
ZTN Tire: Spare LT225/70R19.5F BW R/ST ST TL HWY
ZW9 Body Equipment, Base Body or Chassis Cab
ZYK Tire: Spare LT215/85R16D BL R/PE ST TL HWY
ZYL Tire: Spare LT215/85R16D BL R/PE ST TL OOR
ZY1 Color Combination, Solid
ZY2 Color Combination, Two Tone
ZY4 Color Combination, Deluxe Two Tone
Z49 Export, Canadian Modified Mandatory Base Equipment
Z71 Chassis Package Off-Road
Z81 Camper Special
Z82 Trailer Provisions Special equipment, Heavy Duty
Z88 Conversion Name Plate, GMC TRUCK
01L Exterior Color Secondary, Special
01U Exterior Color Primary, Special
11L Secondary Color Exterior, Pewter Metallic
11U Primary Color Exterior, Pewter Metallic
12U Primary Color Exterior, Linen White
13C Trim Combination Cloth, Light Gray
13D Trim Combination Cloth, Light Gray
13I Interior Color, Light Gray
13V Trim Combination Vinyl, Light Gray
132 Trim Combination Leather, Light Gray
19U Primary Color Exterior, Lamp Black
23U Primary Color Exterior, Ocean Blue
24L Secondary Color Exterior, Opal Blue
24U Primary Color Exterior, Opal Blue
24U Primary Color Exterior, Medium Blue Metallic
25L Secondary Color Exterior, Bright Blue Metallic
26C Trim Combination Cloth, Navy
26D Trim Combination Cloth, Navy
26I Interior Trim, Navy
26V Trim Combination Vinyl, Navy
262 Trim Combination Leather, Navy
27A Stripe Color Accent, Light Indigo/Dark Indigo
29U Primary Color Exterior, Dark Blue
31A Stripe Color Accent, Light SIlver/Dark Indigo
35L Secondary Color Exterior, Laguna Green
35U Primary Color Exterior, Laguna Green
39L Secondary Color Exterior, Indigo Blue Metallic
39U Primary Color Exterior, Indigo Blue Metallic
41L Secondary Color Exterior, Black
41U Primary Color Exterior, Black
43L Secondary Color Exterior, Emerald Green
43U Primary Color Exterior, Emerald Green
46U Primary Color Exterior, Dark Green
50L Secondary Color Exterior, Olympic White
50U Primary Color Exterior, Olympic White
51A Stripe Color Accent, Gunmetal/Ultra Silver
51L Secondary Color Exterior, Dark Toreador Metallic
51U Primary Color Exterior, Dark Toreador Metallic
52C Trim Combination Cloth, Light Neutral
52D Trim Combination Cloth, Light Neutral
52I Interior Trim, Light Neutral
52V Trim Combination Vinyl, Light Neutral
522 Trim Combination Leather, Light Neutral
56A Stripe Color Accent, Medium Beige/Black
61U Primary Color Exterior, Tan
65L Secondary Color Exterior, Smokey Carmel Metallic
65U Primary Color Exterior, Smokey Carmel Metallic
69L Secondary Color Exterior, Copper Metallic
69U Primary Color Exterior, Copper Metallic
71U Primary Color Exterior, Red Orange
72U Primary Color Exterior, Standard Red
74L Secondary Color Exterior, Victory Red
74U Primary Color Exterior, Victory Red
79C Trim Combination Cloth, Ruby Red
79D Trim Combination Cloth, Ruby Red
79I Interior Trim, Ruby Red
79V Trim Combination Vinyl, Ruby Red
792 Trim Combination Leather, Ruby Red
80A Stripe Color Accent, Gunmetal/Light Silver
82A Stripe Color Accent, Light Silver/Dark Green
83A Stripe Color Accent, Green/Ultra Silver
84A Stripe Color Accent, Light Silver/Dark Indigo
87A Stripe Color Accent, Light Silver/Medium Red
90U Primary Color Exterior, Gray Metallic
91L Secondary Color Exterior, Dark Argent
    erickn520
    erickn520
  • Who's Online   3 Members, 0 Anonymous, 562 Guests (See full list)
