Is the '07 'burb on an '06 frame?
Dr. DanH
I read that GM put the new body style onto the existing frame & suspension in the 3/4t Suburbans. I want to put a 4" lift kit on to improve the ground clearance, but so far no one is making a kit. If they are the same frame, wouldn't they be interchangeable?
Thank you,
Dan
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
