airoverleaf questions
two years ago me and my buddies put a 2/4 static drop on my 98 2wd ext. cab sierra. once i got the drop installed... i noticed that the ride on my frontend is perfect but the back is way too soft. i got the toxic shocks that were recommended for my app but it just flat out sucks. i thought about adjustable valve shocks but then i saw the airoverleaf kit from air ride technologies (a little lower in the rear wouldn't hurt). what would be the better choice?
  • 3 weeks later...
When I lowered my 1996 reg. cab short bed Sierra I had the Toxic shocks on there at first as well. I quickly discovered the ride was harsh and sent them back. I ended up getting Belltech Nitro drop shocks for the rear. These helped the truck stiffen up and also make for a more solid gripping rear. These retail for about $80 a pair but are worth it. You could spend the extra $20 and get the Belltech Nitro Active but aren't sure how much better they would be. Good luck and take care. GMC 1996
  • 4 months later...
I wouldnt recommend doing the AOL setup. I ran it for 1.5 yrs before i 4linked it. AOL is a very harsh ride quality. I have pics saved on my computer at home that I will upload if you would like. Just found this site so ill post pics later.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
