OBD troubles
Hi! I have -95 Chevy Silverado 2500 4x4 with 6,5 Diesel. Today the truck refused to shift gears and when I put the lights on the signaltone started to peep. So I suppose there is some kind of communication error between computer and engine. I wasn`t able to get the OBD diagnostic codes, the check engine light just didn`t appear.... I have done it manually many times before just by jumping the A and B terminals by wire, this time it didn`t work.
I had many troubles before with my truck, but this one is something really new. I was also trying to find some answers from the forum, I did find a lot of good information, but not the one I was looking to.
The Finn, From Finland
:flag:
  • 4 weeks later...
Hellooooouu?
I can`t believe nobody had same kind of troubles... It`s getting freezing cold up here on the Arctic Circle, winter is coming. I definetly need some assistance.
The Finn
Hellooooouu?
The Finn
Check the fuses for the power ports. The computer runs off them on the 96-97's. It may be the same with yours.
I checked all the fuses I found. None of them was burned. A :rolleyes: re there some fuses otherwhere like in the cables?
The Finn
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
