Haydens waterless coolant?
  • 4 weeks later...
I've been using it in my KTM (Offroad Motorcycle) for about 3 years. I like it because it won't boil at normal temps and you can run a zero pressure rad cap on the system. I like it because in the past my bike would overheat in the real slow tight stuff even though it was jetted properly. I don't have any overheating issues in my truck so I'm not convinced of the benefit.
I don't know if there is any noticable advantage to using it unless the vehicle is modified or has some overheating problems. On the other hand, if you are planning on running it there are some modifications you can make to take advantage of it's properties. Higher compression and/or higher coolant temps, for instance.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 425 Guests (See full list)
