Oil Analysis
Recently, received my oil analysis and with over 28,000 miles the report shows abnormal PPM of cooper (52).  So, what to do now.  I supposed it's possible the wrist pins still haven't fully broke in, but what if they are, then what?  Anybody else seen high copper counts with this many miles?
I don't know what type of oil you are using, but I would switch to a synthetic oil if you are not using one.  Next I would verify your oil pressure is what your gauge is saying.  Hope this helps
andy
How do you know what "normal" PPM should be?  How are normal limits determined and how are they tested?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
