99 GMC K2500 Classic Interior Option
SAE07
I am wondering since my 99 is identical to the 98 GMC Sierra, were all trucks fitted with the tweeter speaker grill integrated into the door panel armrest regardless of the option level of the stereo or trim?
Is it possible that the lower end trim had no tweeter grill and that the armrest continued on as a pad to the forward part of the door panel?
Or, with the SLE trim and base stereo system, would there have been a tweeter grill or not?
Reason I ask, the driver interior door handle had broken about a month ago. When I was replacing it I noticed that the wiring lead for the tweeter was there but no tweeter mounted into the grill on the armrest.
I ordered the stereo upgrade which should have been UQ3 but shows as UQ5 on my options tag. The stereo did make it into the truck but it did not show up on the window sticker. The tweeter part number is 15177051.
The dealer says that its been too long since I purchased the truck and that I should have pointed that out previously. I would never had known until I removed the door panel to repair the handle.
This truck was in the dealers system to be built as a dealer order when the salesman changed the build designation from a 2wd to a 4wd with SLE trim and stereo upgrade. There were options I received that I did not order which may explain why some items did not show up on the options label or perhaps why I did not get the tweeters but got the stereo.
Thanks
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 458 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
