Temperary cut out at speed and P0300
tfelton
I have a 98 GMC K-1500 Sierra Ext. Cab with a 5.7 Liter Vortec engine 210000 miles. Compleatly STOCK
I have changed the injection spider with the new version from the dealer.
I have replaced the fuel pump about 4 times in the last 2-3 years, changed the fuel pump connector. I have a vibrating fuel gauge and have had from before the first fuel pump. Resently replaced the intake gasket. New distributer, cap, rotor, wires, pluges. Changed the Thottle position Sensor, Camshaft sensor, Crankshaft sensor, 2 new cats, 4 new 02 sensors...I may have forgotten a thing or two like fuel filter everyother month or so and air filters.
I have 2 problems or mayby they are related.
Problem 1: truck runs fine but Check engine flashes at about 2200 RPM. P0300
Problem 2: Intermittent cut out of power. Does not seem to happen in 3th gear.
When this happens it causes an immedate decellaration for about 1 second, then its back. Sometimes it just continues until I eather take my foot off the gas or floor board it. It is such an abupt loss of power that it causes the gears in my transfer case to clash harshly.
I have been fighting with the P0300 for quite a while, but this cutting out thing has got me scared. I almost think the fuel pump is going out AGAIN.
What do you suggest I do? I want to take it to the dealer but I do not want them sucking money that I dont have out of me. And, I dont think they will find the problem. I have read some of the post with simaler problems and they take there truck to the dealer with no resolution.
Pease help, I be your friend forever.
Thanks,
Ty Felton
P.S. Cant believe I am going to say this: But this is making me want to buy a $%^ing Ford. Please forgive me.
This one definitely needs to go on a scanner that can capture what's going on when the problem occurs. You replaced practically everything, so I have no other ideas at this point.
A flashing SES light means you have a potential catalyst damaging misfire. Driving with a scanner so you can monitor misfire data may narrow it down to one specific cylinder. Knowing that would help a lot.
The other problem, loss of power, may or may not be related. It doesn't sound like it is, but I could be wrong.
Sorry, I have no other suggestions without more diagnostic info.
this sounds alot like what happened with my fiancee`'s '99 Jimmy shortly after I got it. I fought that same code for MONTHS (obviously you've been going longer) and it ended up that the cap & rotor were bad (even after I replaced them). Apparently these trucks do not like anything but AC Delco parts. Also, the catalytic converter was on its way out, but didn't totaly fail for another year.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 486 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
