New Guy New Truck New Toys!!
Doogie
Ok so I bought my 06 Sierra Crew Cab Z71 at the end of last month. I got an awesome deal and for the most part got what I really wanted. IE color, crew cab, cloth interrior, Z71, digital climate control, tow package and even some things I didnt care about like the Bose system(Non lux).
However there are a few things that I didnt get that I really wanted. Like I said the price was just too good to pass up, so I thought I would live without some of the things that I wanted. UNTIL I cam across this GOD AWEFUL site :) Now I got the mod bug!!! :flag::flag:
I have looked at lots of posts and done a fair amount of searching but I do not find that any of the information is 06 specific.
The things I want are:
Factory Nav touch screen model that will allow me to keep the rear audio controls
There is one that had a flip down screen with a dedicated Nav drive I would like to
get. PN 15883298 Anyone know if this is lux or non lux? Will it work with my
Truck?
Steering wheel controls with DIC access. I have found some helpful info on this but
sounds like it might be a hassle getting the dealer to reprogram the truck. How
much is the harness? My truck is a non HD
Power folding mirrors. I would love to get those put on my truck, again sounds
simple enought but has anyone done it easily?
Id like to add XM or IPod interface, from what I read that is a either or type of item
Last I would like to add OnStar, Problably the only thing on my list that I will not be
able to get done.
Again I see mixed info on these upgrades, not sure if I can get it all done but would really like to get the Nav and DIC done!!!
Any help is appricated!
Thanks
Doogie
Houston Tx
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 489 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
