10.5 inch rear diff
Is the magnet on the drain plug of this rear axle?  It's on my 2001 2500HD 6.0 4L80E 4X4.  I bought the GM gear lube.  When the Mrs. picked it up she was pretty amused by the "New Grape Scent" on the bottle.
the magnet (on my half ton) is not on the drain plug.  It is actually inside the diff cover.  You have to take the cover off to see the magnet
I don't believe the magnet is on the drain plug.  I think the only rear diff that has the magnet on the drain plug is the new 11.5" monster.  The magnet on your truck should be inside the housing like on Ryans 8.5" rear diff.
  • 3 months later...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
