front and rear diff oil
snorydermb
Well your transfer case should run on ATF (I think...mine I believe does) so I'd suggest switching over to a synthetic ATF in that. As for your diffs, if you don't currently have any leaks at your axle seals, then you should be okay to get a synthetic gear oil in the proper weight. This is my intention once I get around to doing it.
You can use GM's synthetic differential fluid in the front diff... and should use it in the rear. I don't have the part #'s, but any GM parts dept. should be able to take care of you. Also, read this...
Subject: Manual Transmission Fluid Usage in 2007 and Prior Manual Transmissions and Transfer Cases - keywords case fluid transmission transfer #PIP3836 - (06/14/2006)
Models: 2007 and Prior Passenger Cars and Trucks
2007 and Prior HUMMER H2
2007 HUMMER H3
2007 and Prior Saturn Passenger Cars and Trucks
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Unavailability of manual transmission fluid part number 88861800 U.S. (88861801 Canada).
Recommendation/Instructions:
If fluid part number 88861800 U.S. (88861801 Canada) is unavailable when servicing a manual transmission or transfer case, Dexron III can be used in it's place. DO NOT use Dexron VI in place of the manual transmission fluid in any manual transmissions or transfer cases as a failure may result.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
I WOULD NOT, use anything BUT the GM Stuff in your T-case. I'v used Mobile 1, and Royal Purple in the front and rear with no issues and do a considerable amount of towing and also plow with the truck.
Do you have a limited slip rear?
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 888 Guests (See full list)
