Ignition coil
I have a 97 z71 w/ 5.7, and have had trouble starting the truck when it's warmed up, like it has trouble turning over. Now, it turns over but won't start.
Troubleshooting the Haynes points to the coil (faulty coil and defective pick-up coil), and am planning to check a plug to see if I get a spark. (It is getting fuel) I plan to replace the plugs and wires and the coil.
Since I'm in there, is there anything else I should inspect? Is there something I should watch out for? Any help or complements to the Haynes manual's directions would be appreciated.
If you haven't noticed, this is my first getting into the motor of the truck outside very basic maintenance.
Thank you
A blind guess...
It could be the ignition module The heatsink compound usually dries up and the heat kills the module. I used to clean and replace the compound every 5K miles, but I had older HEI which was a good idea but kinda bad also with the heat. With today's CPU heat compounds, it's really cheap and easy to get. Only thin even coats, too thick is just as bad as not having any.
