Got Torque?
KySilverado
Cool pic!
Question: when you launch in 4wd to avoid the rear wheels spinning, I'm assuming you keep the truck in 4wd all thru the 1/4 mile ?
Cool pic!
It has the autotrack transfer case. At the track I will go 2wd right after the 1-2 shift to keep traction through the shift. Great debate on how the system reacts to this. I am fairly confident that the transfer case doesn't provide power to the front but don't think the front axle can unlock under torque. I have tested at the track. 4wd runs the entire lenght are about .2 slower.
Thanks for the response!
One of the days, I gotta take my truck to the track.
  • 4 months later...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
