tow/haul
is there any known issue where when the tow haul button is pushed the light doesnt come on, maybe the tow/hual mode does not engage as well? this is on a 2003 chev/silv...any ideas? where to start looking i cant see that bulb burning out but i guess its possible? any ideas where to start looking would be appreciated
YukonJeff hit this...
YukonJeff
post Dec 2 2003, 07:07 PM
Post #7
GM-TC Newbie
Group: Members
GMC
2000 Yukon XL
View Vehicles
Good news!! Easy fix! Removed the steering column shroud and there's an orange cased pair of wires that come out of the base of the shift lever and head down behind the dash. About 2 inches from where they emerge from the shift lever they were cleanly broken off. Almost looks like they may have gotten pinched in the mechanism that allows the shift lever to move front to back. So, easy splice and I'm back in Tow/Haul mode!
had to fix my wires the other week. It's pretty easy and you wont have a problem finding them. They jump right out at you when you remove the shroud.
Before tearing apart your column, check your owner's manual. I have a dim memory that this function is protected by a fuse that also protects some other obscure stuff. You can also drive the truck and try to engage t-h mode--the tranny shift differences will be obvious when you wait to 2500 rpm to shift.
Sounds like a similar problem to the old-style cruise in the turn signal handle...after a long time of being flexed back and forth the wires simply break. Not too bright by GM in my opinion.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,259 Guests (See full list)
