couple of questions from the new guy
Been checking around on some Alcoas recently and was told that only the outside rim is needed on the rear of a dually (outside Alcoa- inside stock), is this the norm for anyone running aftermarket rims on their dually?  I assume my truck is a 1 ton (it has a 14 bolt full float axle), would this make it a 1 ton truck or are there other indications to check for?  Lastly, I have a GMC Sierra SLE 3500, can anyone tell me what the meanings are  of  "SLE and 3500"?  Any info is appreciated, I just recently bought this truck three weeks ago and am very new to the world of trucks if you can't tell already. :wink:
Welcome to the Forum.  I'll see if I can help you figure out a few things.  I don't know how dually guys place aftermarket rims, but it sure seems cheaper to buy 4 than 6, and if no one can see the inside wheel....
 To answer 2 in 1, the 14 bolt isn't how you tell a truck is a one ton, but the "3500" is.  With Chevy's 1500 = 1/2 ton, 2500=3/4 ton, 3500 = 1 ton.   Also all dually's are 1 ton, and there are single rear wheel 1 tons too.
 The SLE is a trim package, ie seat style and cover, power lock/window options, stereo, etc.  I'm not sure what the Sierra SLE on a '90 includes, but I think that package has all the bells and whistles.
 Hope you're liking your new truck and will enjoy this site-
14 bolt full floating axles only came on the one tons, the three quarter ton trucks have 14 bolt semi-floaters on them.  All factory duallys are also one tons.  And like DigUout said, since you have a 3500 it is a one ton for sure.
By the way, welcome.  Come visit us here in the HD forum often!
Jp-
I thought the 2500 8 lug HD's came with the full floating and the 2500 6 lug came with the semi floating?  Or am I misinformed?
That is what I used to think, but then I read an article that proved me wrong.  There is a K2500 sitting in my driveway that has the semifloating axle under it, I took off the cap and checked.  The K3500 we used to have I did the same thing to and found the full floater.
Yeah, they're right about the 1-ton indications.  Do you have to use the stock rim on the inside duals?  This would make tire rotations very expensive if you wanted to include the inside duals in the mix.  But I'm sure you could get away with only rotating the outside duals with the fronts; rotation is mostly to correct wear on the fronts, anyway.
Thanks for the info guys, I really appreciate it.  The reason I was asking about the rim setup is I had emailed a company called Southwest Wheel about a shipping quote for two front and four rear Alcoas, and the reply I had gotten from them said that only two Alcoas are "allowed" for the rear.  I met up with a guy this past weekend with a '92 3500 Chevy dually w/Alcoas, and sure enough he had the stock rims for the inners.
(Edited by KENNE BILL at 8:16 am on July 31, 2001)
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
