Rear power windows problem
DBRAV1
The rear power windows on my 2000 Tahoe don't work. Fronts work fine and relay clicks on the back doors, but nothing happens. Is this possibly a bad window lockout switch, or is there a relay somewhere I don't know about?
If you hear the relays click in the back doors, it could very well be bad motors. Yeah, seems odd that you'd have two that'd be out at the same time, but it's possible.
Pull one of the rear switches out and check for power/ground on connector terminals A and B. A is a dark blue wire (there are two dark blue wires in the connector so make sure you're in terminal A) and B is brown.
Operate the switch UP and you should have power coming out of one of those two wires. Operate the switch DOWN and power will then come out of the other wire. Wouldn't hurt to check ground (same way). If you have power and ground then it's the motor or its connections.
Hi DBRAV1--I've had 3 rear window motors replaced on my 2001 Suburban, fortunately all on warranty. Dealer said they were all shorted, and get shorted due to lack of use.--Frank Sub
Thanks for the input. I pulled the door panels and checked the power and it is getting to the motor, so I guess I'm in the market for new motors. I bought this truck used and the previous owner said no one ever rode in the back so the windows weren't used much. I was hoping for an easier fix, but at least it is narrowed down now.
Thanks - I think I have the same issue as I bought this truck used from an older woman who rarely had people in the back seat. I've never heard of shorting out from lack of use, but the motors are definitely not working.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
