2006 2500 HD
JLINC915
I have a 2006 2500 HD with all towing and plow options. For the last couple thousand miles I am getting a vibration radiating up through the steering colum to the steering wheel, seems to be coming from the front suspension? It happins over the smallest road imperfections, but more prominant when steering to the Lt or Rt. The dealer replaced a "lube kit'? at the last service but the problem has worsened.
Thanks Jim
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
