engine heaters
kingsfisherman
2003 2500HD 6.0, Alaska, not sure if this truck has any kind of engine heater already installed,havent seen anything to indicate that it has one.Would like to install a pan heater,but not sure about the block and which type to install,either freeze plug or tank type, did a tank type on my last truck a 97 2500,not a lot of places to install one so we had to be creative,dont want to do that again.Anyone done an installation of either one of these on a newer truck? Thanks for your help.
well took a look around the engine and couldnt find any sign of a heater,so back to
looking for a recommendation on a engine heater.
In my 02 sierra 2500hd, there is a plug (regular 3prong 120v) tucked under the drivers side wheel well. I've personally never used the heater but it was an option the truck already came with and i wasnt about to ask them to remove it. If you have already looked and cant find it, then chances are you dont have one, but i figured i'd mention it anyway.
Look in your glove compartment at the RPO code list. If you see " K05 " your truck is equiped with an engine block heater.
