Pictures of 4 High Mod+Fogs
Bogle45
Does anyone have any pictures of how they did their 4 High Mod. I was thinking about doing it to my truck. I'd like to see some pictures of how to do it though. Thanks
I did my 2000 ECSB 1500 Z71..............its real easy on our trucks.
Unplug the harness(plug) off your low beam lights............one of the wires is yellow. Cut this wire......not too close to the plug.....then take the yellow from the plug........and ground it somewhere near by. You will most likely have to add a piece of wire to it.......the other end of the yellow which essentially just runs into the main wiring harness of the truck, just tape it up real good..........its only a ground anyways.
Thats it............your low beams will now stay on when you put your high beams on.
I did this last year and have had no problems what so ever.........all you are doing is giving the lights a constant ground instead of an intermitten one from the trucks wiring system.
:chevy:
I tried this on my '05 Silverado. First off, the yellow turned out to be the hot, not the ground. After I fixed that I tried the mod with the black. Didn't work. Pulled out my tester and found that the ground is constant. It's the power that's intermittent. I guess the solution may be to steal power from the hot lead on the high beams. I don't know if it'll maybe overload the circuit though. Maybe a diode will need to be installed on the low beam hot lead to keep voltage from feeding back to the computer or wherever it goes? I don't really know if it matters. Any thoughts?
  • 3 weeks later...
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
