Delphi Navigation
Ok...I have an 06 GMC Sierra I am trying to install the factory delphi nav system in. I have it installed , but it is not functioning correctly. GPS signal is iffy, at best. Directions lag behind reality. I was told that i needed to check the instrument cluster for the vss wire. I did see the green wire with the whote tracer in the approriate pin in the instrument cluster harness, but it must not be hooked up because I can go down the road & manipulate system, i. e. new destination, etc.
What am I doing wrong? This thing is kicking my butt!
Thanks
Thanks
is there wire going from position A4 on the instrument cluster to position E of the radio connector (the small connector of two)?
yeah, like poonis said. Everyone will find the wire at the cluster. That doesn't mean that it connects to your headunit. You need to splice into that wire on the cluster, and run your splice over to the appropriate pin on the back of your headunit. Then you'll be good to go.
Also, some folks have run their splice through a switch, so that you can keep it on all the time, unless you want to have your passenger (not safe for you to do it) enter in a destination on the fly. You can just flip the switch, enter the destination, then flip it back. Worth the effort, if you ask me.
on your year truck, you said 06 right? you shouldnt need a wire from the cluster at all. shoulnt. you have the delphi tnr800? i just installed one in my dads 05 silverado 3500 a few weeks ago. as stated in your instruction manual, MOST 04 and up models come equipped with that wire in the radio harness. the smaller of the two. in the E position i believe. thats it. now, if you dont have that wire installed in your harness then you will have to run that wire that came in the box, from the gauge cluster to position E of the harness. and as the last thread said, i did install a switch, so that when you flip it, itll allow you to enter in POI and address info, then back to navi with another flip. also as they said, the gps antenna, make sure its well connected. thats all i can think of. good luck
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
