Tranny delay/slip when starting out?
I am new to chevy but my 2004 tahoe has slipped on two or three occassions since i bought it a month or two ago. At a light, i hit the gas and it didn't go. I let up on the gas and hit it again and it took off normally. I bought it used with 37k miles. The only other thing i notice is the tranny from first to second has a very slight bump. It isn't very noticeable, and not bad, but not silky smooth like the other gears. I have had no engine or tranny lights go off and the issue from the stop light shows no other symtoms, but i find it strange.
any ideas? should i be concerned or no big deal?
Sounds like the old "starts in 2nd sometimes" issue. My original trans did it a handful of times per year. My completely rebuild trans does it with the same frequency. It also did it with my stock tune and my wait4me tune. I'm thinking it is a programming issue where under certain conditions it mistakenly selects 2nd gear. I can now tell when it is happening so I ease off the gas and it goes back to first. When it first happened, I gave it more gas and it kind of slammed into first. Bottom line for me is it doesn't happen enough to spend $$ on it.
If you are good enough buds with your service advisor, he/she could get it done for free by GM.
For example, I just had my slip yoke changed out for the nickle plated one and front U joint done under factory warranty at 63,000 miles.
I have had this problem from day 1. The dealer flashed the PCM and it does it less often, but it still does it. I have never been able to duplicate the problem reliably. If anyone can, post it here and tell your dealer so that the programmers can debug it.
It happened in my wifes 04 Tahoe on the way home today. I can remeber it happening about 10 times or so in the 3 years we have had it.
I need to bring it in for the rear seatbelt recall.....I will mention the TSB - do you have the number of it ?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
