Car amp converter to House plug
mattro
Anyone know what the converters are called that take a car amplifier and allow it to be changed so that it can plug into a standard house wall socket? Home amps are expensive and this would be much cheaper.
Thanks
Matt
Are you talking about these things? You should be able to get those at any RadioShack.
However, what you want to do just isn't going to work. None of those converters will be able to run any serious car amplifier (and if you can find a converter that will, it will cost more than any decent home receiver anyways). Just drop the cash for a real home receiver, JVC and Sony make some nice receivers for around $200. It will preform much better and will look less "jury-rigged."
yes something like that also that can handle some amplifiers. I have a Panasonic(not my favorite brand) reciever setup to run 400w off the reciever and an amplifier is already powering two of my speakers. Guess i ask for too much
Never mind ive got a 400w home theater reciever not an amp the amp i have isnt much(home amp) but ill probably get some of those converters and car amplifier i have laying around.
(watts divided by 13.8 = amps)
It's called a trickle charger and a hidden battery :)
