exhuast questions
I am on the market for a new exhuast system on my 98 Z71, I recently cracked my driver side pipe and had to get it temporary welded back together, so now I am on the market for a new setup. Anyone have any suggestions on brand? flowmaster? Gibson? I'm looking for a nice tone at idle and acceleration along with HP and Torque increase, also needs to be able to with stand towing and off-roading, Little new at this so any help would be great.
Thanks
I've owned several GM trucks in that era and have always had good luck with the flowmaster products. If you want the interior noise minimal you should go with the delta flow muffler. If you want a real throaty loud truck go with the 40 series. I had an '01 GMC with the 8.1 and had an 80 series big block muffler on it. It sounded great. That muffler was a dual in dual out configuration. You may even look at the hush power series as well. I don't have any experience with them but they look like a great product. Anyway, food for thought.
cwh
I have a Gibson cat-back on my truck. It's a stainless steel setup, so after 4 Canadian winters, it's still very solid.
There are so many systems out there and in the end, it all boils down to personal preference.
Here is a sound clip of my setup (it's a little distorted, mp3 players do not make great audio recording devices).
http://s64.photobucket.com/albums/h190/pwa...onXLexhaust.flv
All the best in deciding which brand! ;)
Thanks for the Input, I've been liking the Gibson dual sport catback and the gibson split rear catback exhuast systems, but from what i was reading, they dont suggest off-roading and towing. any ideas? I love how your yukon sounds, but i think i am leaning to a dual exhuast system over a single.
I don't understand why Gibson would say no off-road or towing.
One of the main reaons to go with a better exhaust is for a litle more power to help with towing. That was the reason I explained to my wife anyways. ;)
the other reason is pure vanity....better sound!
Yea, never though of that.
My exhuast is a side exit so it wasn't an issue for me.
Split rear...could they recommend not towing for the bounce back sound you will get from pulling a trailer?
Let me rephrase that:
" Muscle-car style and rumble! Not recommended for towing or heavy-duty off-roading. Some lowered trucks may require rear shock relocators. 50 States Smog Legal"
I missed the Heavy-duty off-roading part :banghead:
Is there any benefit from having a Dual side exit over spilt rear? besides the sound when towing? or is it just the looks and personal preference?
it is not so much of bounce back, as exaust fumes being trapped. like a travel trailer, or camper shell. in most states it is agenst the law. here in CA it is becouse people were dieing from riding in the back of pu's with caps on them with duels running out the back becouse of carbon monoxide.
:cool:
  • 2 years later...
Just curious if anyone has any good ideas what to do with exhuast. i want to change mine out. iam sick of that high school sound pipes haha. i got true dual no cats 2.5inch back to a set of 24inch flo pro straight through glass packs. i want to go to a high performance muffler thats gonna give me some horsepower. i want a nice deep throaty sound with some muslce behind it. i was told to switch to 3 and a quarter piping going to a dual in dual out magnaflow but iam being quoted around $850 for the system. anyone got any ideas that will save me some money and yet get a good decent sound
I have the Gibson single side exit. Gibson recommended it for towing because of the bounce back that straight duels give. Also the starting torque range is lower with a single exhaust, ie... better for towing. I love it and keeps they sound at a perfect level for long hauls with the toy hauler. Also works great with cylinder cut out, no droning
hmm. that is a pretty good price to! yeah the 3 inch piping sure got my eye. my old truck (which i still have) i got 3 inch piping from the header back all single exhaust going into a v force muffler. then into a 4 inch tip. Truck sounded really good but the only thing, it had a droned sound. I noticed that gibson only had one single pipe entering and you can get one or two going out. you know if you can get some kind of adapter thingy haha to go from duals to single to that muffler?
    Bulldogger
    Bulldogger
  • Who's Online   3 Members, 1 Anonymous, 728 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
