4WD problem
dmilacek
I have a newsytle 1999 Silverado 4WD 5.3 L. It has only 53000 miles. I have had some intermittent problems with changing between 2HI, 4HI, Auto4,etc. in past years, so I replaced the dash switch thinking that was the problem. While attempting to test drive and utilize each function, the pickup had some troubles. While switching out of 4LO, it temporarily seemed to be partially in nuetral, then it switched to 4HI and will not change out. The light blinks and there is clicking and a buzzing from underneath, but then it fails. Also, the front wheels seem to be locked more than normal in 4HI mode. It doesn't want to allow turning and then seems to be dragging, grinding while going straight. I am hoping for some diagnostics that I can try before taking it into the dealer.
Lots of switch problems on those, but you say you already replaced it, so that leaves that out.
Probably an encoder motor or encoder sensor problem. Nothing you can diagnose in the driveway.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,259 Guests (See full list)
