workers' comp. question
skrat
My wife is filing a workers’ comp. suit against her company because she got a bad case of mouse wrist from their negligence of ergonomics. They bought her Dragon Naturally Speaking ( http://www.nuance.com/naturallyspeaking/ ) at work, but she still does about an hour of work a day from home, and I think they should legally be required to provide her with it at home if she’s working. Anyone know if that’s true? We live in California.
Do they orovide her with a computer at home? Or does she just do some work at home just because she wants to not because they make her? If they don't require her to do work at home then they should not have to furnish one.. IMO
Get a different kind of mouse.
I use 3 different kinds on several different computers to mix it up, and don't have any issues. I've been working on computers (typing and such) for 20 years.
The computer at home she bought, but she deducted it. And she is required to work from home. But I just realized you can install Dragon on two computers. *doh* So that takes care of that.
And wingnut - you are lucky. Believe me, everything else was tried. Some people's physiology is just more resilient than others.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
