2003 cabin air filtration replacement
Lizzyb4
I have a 2003 GMC 3500 series pickup that had a fire underneath. Now there is a bad smell in the cabin and need to replace the cabin filter. How do I do that. Cannot find instructions anywhere. I have the filter. Just need instructions. I also have a 2003 Suburban and will also change that filter if I find out how to do this without any problems. I am a female so need good instructions. Ha Ha :D
I'm going to give you real easy instructions... take the filter back and get your money back. Your truck does not have a cabin filter. That was eliminated in 2003. Here's a TSB explaining this change...
Subject: Passenger Compartment Air Filter - keywords dirt dust HVAC case #PIT3330B - (08/02/2006)
Models: 2003-2007 Cadillac Escalade Models
2003-2007 Chevrolet Avalanche, Silverado, Silverado Classic, Suburban, Tahoe
2003-2007 GMC Sierra, Sierra Classic, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2003-2007 Hummer H2
This PI is being updated to add models. Please discard PIT3330A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer may inquire about the availability of the passenger compartment air filter.
Recommendation/Instructions:
Starting in the 2003 model year, the passenger compartment air filter is no longer available as a factory option. With the redesigned HVAC case, the opening for the filter cavity has been molded over.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
The 2003 and up do not have cabin filters.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 1 Anonymous, 611 Guests (See full list)
