power problems
Sierrawolf
Hello their im haveing problem electrical with my 03 sierra. I just went threw 3 alternators (cause im into audio and have a high power one now ) But i wanted to know why my volts keep droping when im driveing then come to a stop. When my a/c or heater on my voltage will drop from 14v to 12 or 11 volts and sometimes drops my rpm down causeing my truck to kill. Someone told me about an up grade for the CPU from stoping that problem but i would like to know if it something else that can be done to. Already had the alternator checked and it fine working like it suppots to be. Im Close to 50k on the truck. So please does anyone have any imputs ?
When idling, the alternator does not achieve it's full output capability. It is not abnormal for the voltage to drop to 12 volts at idle when you have a load on the electrical system (headlights, heater blower, etc.). I've even seen near 11 volts with high loads when there is absolutely nothing wrong with the charging system.
As for the idle stalling problem... clean the throttle body.
I'll try that but also it does that even when their is not a load on it. When im driveing down and just have the windows down and no radio or lights on it just puzzeling. I will try clean that to see whats happens.
Perhaps I wasn't clear. I don't believe the throttle body cleaning has any relation to your voltage question. I took the low voltage and stalling as two separate issues.
Hopefully, cleaning the throttle body will fix the stalling condition. Voltage is not causing it, nor will cleaning the throttle body raise the voltage readings significantly, if at all.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
