Axle swap- speedo correction?
I'm thinking about swapping the noisy 3.23 open rear end in my '07 Classic Crew Cab for a 3.73 locker like I had in my '04 EC.
I have found several low-mileage '06s and even a few '07s in salvage yards for around $1500.
Can the dealer reprogram the PCM to make the speedometer read correctly with the new axle ratio?
They should be able to. Just make sure that if you have a 4 wheel drive truck, you don't shift into 4 wheel drive until you have a 3.73 in your front differential as well, or you'll be experiencing some bad times and possibily need a new transfer case.
If you're 2 wheel drive, then do it and have fun!
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
