VIN lookup
Is there anyplace where I can go to search by VIN what accessories are on my vehicle?
Like when I put in my VIN it will tell me if I have a towing package, what gear ratio I'm running, etc....
Go to your dealer Service Manager and ask him to run a Vehicle Service History on your VIN. It will show option information, date built, and any service work done at a GM dealer.
The Service PArts Identifier sticker in the glove box will show the RPO codes yur truck has.
Thanks for all the help. With the help of the RPO codes I found I must have about all the options. And with the help of the guys over at another board, I found it has had no major work done by GM.
This board rocks!! you guys are great.
-robert-
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
