1999 Chevrolet Suburban
keebler
I recently looked at some information on my 1999 Chevrolet Suburban from the GM Vehicle Inquiry System. I've seen this kind of information before but theres a couple of entries I don't understand. Maybe a Tech can help...
REQUIRED FIELD ACTIONS
Type -- Number -- Description -- Posted Date -- Status
RC -- 00044 -- FMVSS NECK EXTENSION REQUIREMENTS -- 12/19/2000 -- Open
Do I have a recall that hasn't been corrected?
CLAIM HISTORY
Repair Order Date : 11/15/2004 Repair Order Number : 261140 Odometer Reading : 93167 miles
Serviced By : RIVERSIDE CHEVROLET
PO BOX 2679
TULSA, OK 74101-2679
(918) 446-2200 Selling Source : 13 - CHEVROLET
Site Code : 05225
Business Associate Code : 167909
Cycle Date -- Cycle Nbr -- Case -- Type -- Labor Operation -- Part -- Comments
11/26/2004 -- 538 -- 01 -- # -- V0649 - 1999 CV & GMC C/K - CUSTOMER DECLINED TRAY FORM COMPLETE -- N/A -- N
What could THAT be all about? Declined?
Yes, that's a recall that was not completed.
Here's the deal. This is the only recall I've seen where you can opt out of it. Why? Because it's this ugly piece of black plastic that gets screwed to the top of the dash on the passenger side. It fits in that depression in the dash. I guess in a crash, your chin could catch in that depression, causing injury.
To date, we have not put this plate in one vehicle. All customers choose to opt out of it when they see what it is. When they do, they have to sign a paper that says they know about it and don't want it. That's what the, "CUSTOMER DECLINED TRAY FORM COMPLETE" means.
If you've owned the vehicle since new, then you signed that paper or someone in your family did. If you bought it used, then the previous owner was the one.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
