Wiring Diagram
Silverado25004x4
Yes ive been lookin around and ive found plenty of web sites that have the diagrams for my truck but you have to pay, since im still in High School im lookin for a free diagram, one for my entire truck, I have too many extra wires/plugs and things i want to know, The one i want most is of my fuse boxes and my dr side floor plug panel. so i can add wiring for acc. and make it look stock, plus then ill be able to make it removable if ever neccassary, since the warrenty is still good and if ever i have to take it in for work i can easly pull the acc. out and they will never know.
There is no such thing as a wiring diagram for the entire vehicle... at least not from GM. There are too many complex systems and the diagrams are broken down into specific items. There are probably several hundred diagrams for each vehicle.
well thats what i ment, sorry for not saying so to start with, thought i did, but yeah, thats what im wanting if possiable, just mainly a place or number of places that have diagrams for my type of truck, but no site that only has diagrams for audio/securty/cruse control. cuz im tired of only finding those sites
I'm in the same boat, wanting everything to be reasonably close to factory.
First I went out and bought a Haynes manual for $35. There are decent wiring diagrams but they suck in that they don't show pin numbers at connectors, only colors. I still think the book is useful due to all the other stuff it shows.
Next I went down to the library and made copies of their Mitchell's wiring diagrams. Most are identical to the ones in the Haynes book, except these have pin numbers.
After lurking through a ton of forums I've managed to put together a decent pinout for the 99-02 MBEC (between the pedals)
C3	Color: Gray	Part#12193928	Cel PhoneA	Orange  2240	Hot at all times	B	Dark Green	835	Diagnostic Signal (E&C)	C	Yellow  243	Hot in Acc or Run	D	Orange  1044	Serial Data Link	E	Pink  739	Hot in Run or Start	F	Black  1850	Ground	C4	Color: Black	Part#12193930	SEOA	Orange  2340	Hot at all timesB	---  ---	Not used	C	Black  2550	Ground	D	Yellow  243	Hot in Acc or Run	E	Pink  739	Hot in Run or Start	F	Orange  2240	Hot at all timesC5	Color: Brown	Part#12193924	TrailerA	Light Blue	1620	Trailer brake switch feedB	Red  142	Hot at all timesC	Dark Blue	47	Trailer brake feedD	Brown  2409	Interior park lamp feedE	---  ---	Not used	F	Black  1850	GroundC6	Color: Grey	Part#12194036	VanityA	Pink  39	Fused Ignition Positive Voltage (Mirror, HVAC-Auto)	B	Dark Blue/White	149	Courtesy Lamp Feed	C	White  156	Courtesy Lamp Output	D	Orange  1732	Electronic Control Unit Output	E	Orange  1732	Electronic Control Unit Output	F	Orange  1732	Electronic Control Unit Output	G	Light Blue	1620	Fused CHMSL Feed	H	Brown  2409	Fused Interior Park Lamps Feed	J	Light Green	1324	Backup Lamp Switch	0.35 mm²K	Black  1850	Ground (HVAC-Auto/Interior Lights - 06)	L	Black  1850	Ground (CHMSL/Vanity Mirror)	M	Black  1850	Ground (O/H Reading Lamps, Rearview Mirror)	C7	Color: Green	Part#15319873	ClutchA	Purple/White	1035	Starter Relay Feed - CoilB	Light Green	2806	Clutch Pedal Position (CPP) Switch FeedC	Purple  420	Brake Pedal Switch Output - TCCD	Brown/White	379	Clutch Pedal Position (CPP) Switch OutputC8	Color: Gray	Part#15306302	Heated SeatA	Orange  Hot at all times	B	Orange  Hot at all times	C9	Color: Cream	Part#12193922	SL RideA	Black  1850	Ground	B	Tan/White	1384	Selective Ride Control Switch Signal	C	---  ---	Not used	D	Purple/White	1382	LED dimming signal	E	Pink  739	Fused Ignition Positive Voltage (uplevel)	F	Gray  8	Instrument Panel Lamp Feed	C10	Color: Cream	Part#12194028	Aux OutletA	---  ---	Not used	B	Orange  1040	Battery Positive Voltage	C12	Color: Cream	Part#12194033	UpfitterA	White  156	Courtesy Lamp Output	B	---  ---	Not used	C	Dk Green/White	817	Vehicle Speed Signal	D	Orange  2240	Hot at all times 	 C14	Color: Black	Part#?	Power SeatA	Orange 	 B	Orange
You do realize that new vehicles have computers that will tell a service technician whether or not anything has been toyed with right? Theres people who have put programmers in their deisels, blown out a tranny, taken it in, and when the service guys ran the readings on the computer, it showed way too high of horsepower and torque outputs, and the tranny wasn't covered due to that fact. It also usually shows electrical draws from fuses and will compare them to normal draws on those fuses.
I wish! The Tech 2 we use in service will show none of those things. In fact, you could bring your vehicle in with a performance calibration installed and we wouldn't be able to tell unless you had a big WESTERS label on the PCM. :)
How is it possible that they didn't cover it under warrranty? They showed us the graph of the RPM's being turned and the speed, then the tech said he was racing, therefore it wasn't covered under warranty. I know Ford does this too, there was a case that went to court over it. We read about it in my business class.
