03 Burb Drive Train
zickefoj
I have something leaking from the front of my 2003 Suburban and I believe it is Gear Oil, however I am not sure how this is possible. It appears as thought the leak is right where the drive shaft enters the Tranny? This should be Trans fluid - corredct and it should be red - at least this is what the dipstick shows.
In any event there is a leak that I am sure is gear oil is coming from a seal where the drive shaft connects at the from the 'tranny?'
Number one what is it that my drive shaft connects to and number two is there anything I can do for a seal leak next to a seal replacement. If a replacement is the only option then any recommendations on where to go or what should I be looking for?
Is this something I can do? I am not claiming to be a full blown mech., but I have tackled things before that even I was amazed when I was done.
Thanks in advance for your time and help.
Regards,
Jeff :driving:
Sounds like your front diff is leaking at the pinion seal. I would take it to the dealer and have it replaced. If you get the pre-load incorrect, you will have major damage. Should not be to expensive. About 1 or 2 hours labor and probably $20 in parts.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 922 Guests (See full list)
