oil change on new 07 denali XL
No listing for an oil filter. More to come as AMSOIL updates their data base. But it does take 6qts of oil. Listed spec's below.
"2007 GMC TRUCKS DENALI 6.2L 8-cyl Engine Code L92
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
All Temps......5W-30[1]
Below -20°F......0W-30
Automatic Transmission.....AF6
Differential, Front .....GL-5[2]
75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Standard Differential, Rear Others.....GL-5[2]
75W-90
Severe Gear 75W-90
Transfer Case,NR3.....SLF[3]
No AMSOIL Product Recommendation
Fluids
Power Steering Fluid.....PS
Brake Fluid.....HB
1. SAE 5W-30 is preferred.
2. Synthetic lubricant, GM part no. 12378261, specification
No. 9986115.
3. GM part no (USA.88861800) Canada (88861801)
CHASSIS LUBRICATION
Two-wheel drive
6 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
11 Fittings, 0 Plugs..........LB
CAPACITIES
Engine, with filter..........6.0 quarts
Cooling System, Initial Fill..........18.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.7 pints
Differential, with 8.6 ring gear Rear..........4.2 pints
TORQUES
Oil Drain Plug.....18 ft-lbs
Transfer case NR3
Fill Plug.....18 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)"
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 478 Guests (See full list)
