Starter noise/problem
ljt190
2003 Sierra 5.3L
On the first start of the day the start is followed by about 2 seconds of a hard to describe noise. Sounds like the starter is perhaps sontinuing to try to start, but I'm not sure. Only does it when cold (not outside temp but first start. Is the starter going?
Thank you.
2003 Sierra 5.3L
Thank you.
Sounds like the solenoid is hanging up....I'd yank that starter before you do ant damage to the ring gear. Ypu may get away with just a solenoid
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
