BFG AT psi recommendations
Howdy, All!
I recently put a set of BFG Ats in a LT265/70R17C rated at up to 50 psi on my '04 Z71 Suburban . Being new to this particular tire, I'm curious what psi you would recommend running for maximum tire life. I'm currently running them at 45 psi, but I have no idea if that is good, bad, or ugly!
I much appreciate any opinions you may have!
Regards
Given how heavy a Suburban is, I would have gone with a load range D in that size. However, I'd say 45 is okay. It might not be optimum but it's a good place to start. It will also give you better mileage than running at 35 psi.
The best thing to do is run at the pressure for a while, then check the tires to see if the center is wearing faster than the sides. If that's the case, air it down some. If the sides are wearing more, add more pressure (up to the max).
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 698 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
