2000 Radio
I was wondering how I get the faceplate off to be able to get to the back of the radio? I know that for a lot of cars you need keys. Do I need keys or just a handy screwdriver?
Thanks
Tim
Thanks
Tim
If you are talking about the dash panel, then that is easy. Turn your key to the on position, pull gear shift lever down (make sure you're not on a slope or put your e brake on)and pull on dash from the LH edge and you will see it releases. From there, just keep pulling on dash until it comes off....work carefully ....from there, you will see two black "tabs" on the side of the radio....squeeze them together, and the radio will slide out. Then release the wiring tabs on the radio connectors and it's outta there!
Thanks
Tim
:loser:
    liddlera
    liddlera
  • Who's Online   2 Members, 0 Anonymous, 389 Guests (See full list)
