Random service 4wd light 2000 z71
ssjeff
I have been getting a random service 4wd displayed. Sometimes the lights go off on the 4wd selector buttons. It usually goes out when I turn it off and turn it back on.
I have had it not come out low4, until I shut it off the ignition and started it back up. I had it in nuetral everytime I tried to change in or out of 4low.
I have seen that I should change a switch posted on some forums but there are multipe switches. Which switch is it that I should change?
Probably would be cheaper for me to change things out till it works than to go to my dealer and pay them to do it.
I appreciate you opinion. Thanks
This happened on my 2000 GMC Yukon and I replaced the 4wd selector switch and that is part # 15709327. Light has not come on since then. I have also read that you can resolder the switch but I just replaced it.
//90GMCZ71
  • 11 months later...
//90GMCZ71
I pulled the selector switch out of the dash and took it apart, did not see anything that needed resoldered. I reinstalled it and then the lights wouldn't work so I went to autozone but they did not have it. I the went to a chevy dealer and it cost me around $50. Everything works great now.
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 581 Guests (See full list)
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
