stock 2006 sierra rims
I've got a little issue with my rims, seems the left over brake dust or road salt is tarnishing my rims...
at every "spoke", there's a brown type of stain i can't seem to get rid of. I'd like to, but am afraid of ruining the finish. what can I do?
bump
You could try the chrome polish, if they`re chrome, and follow up with wax. You could try the clay bar to remove the rust also, then polish. If they are pitted, I think your not going to get that finish back. Keep them polished and waxed every 3-4 months, and that will help protect them.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
