Reverse signal wire lead.
02DenaliBaby
I will like to know where is the reverse signal wire is located in the BCM module? I have a rear view camera and I want it to activate when shifted into reverse.
I dont think it goes through the BCM, best place to tie in would be at the VEH/BU 15A fuse at the underhood fuse panel. Also it looks like theres a light green wire that goes to the inside rearview mirror and has battery voltage when in reverse. This would probably work too, might have to use a relay, not sure how much power that thing draws.
Thank You. I will try this. By the way the camera is only 12V
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
