A couple of things to get rid of
Stock cat back from a 2003 Sierra EC-SB in one piece I was able to remove it without cutting it. Free Local pick up only too big to ship.
Black outside door handles from same truck. Make offer.
Where are you located? I've been trying to find a factory exhaust like that. I'm in NC.
How did you get the exhaust off without cutting?? I need to remove exhaust from an '03 2wd and need to put it on another '00 I am selling and dont want to cut.
My truck was 4wd but it might work in your case too. I put floor jack with a good piece of wood under the trailer hitch and jacked the truck up to take all the travel out of the suspension.The tires were only off the ground an inch or two. Once all the hangers were off I snaked the tailpipe out from between the shock and axle and pulled the whole system out the passenger side. It was tight but came out without too much trouble. I didn't want too cut mine either incase I didn't like the Magnaflow. I did the whole removal and installation in about an hour including getting the broken bolts out of the cat flange.
  • 5 weeks later...
u need to remove the back passanger shock then it will slide righ toff
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 517 Guests (See full list)
