Wheel Backspacing?
Hey guys,
I'm going to get new wheels for my truck.  Looks like the front runner is the American Eagle 143.  My question is how close I need to come on the backspacing issue?  I believe that these wheels have about a 4.75 inch backspacing.  I'll be running 265/75 R16 BFG AT's on these wheels.
Any thoughts??
Thanks
Sean
4 3/4 should work.  I'm running 4 5/8" with my Centerlines, with no problems.
5" backspacing will not work.
Try a wheel on the front of the truck before you mount the tires though, just to make sure they fit. If you mount 'em, you bought 'em.    ???
Why would a 5" back spacing not work?  The factory wheels are 5" back spacing.  I just bought a eagle wheel with a 5" back spacing "16X8" and put a 295/75-16 BFG A/T on it to do a test fit. It fits perfect,and it doesn't stick out past the fender flare.
Yes
I also thought that the stock rims were 5 inch backspacing...Why aren't you supposed to use this backspacing with aftermarket rims??
Sean
The factory wheels are 5" backspacing. I shouldn't have said they would NOT work.  :blush: My mistake. :blush:  The difference come with the build of the wheel- some are quite a bit thicker and beefier, causing interference with the calipers or spindles. Some of the 5" BSP wheels will work, some will not. The best thing to do with ANY wheel is to test fit them before you mount the tires, 'cause just as I said in the prior post, 95% of retailers have a policy of you mount 'em, you bought 'em, both the tires AND the wheels. ???
Give the 5" BSP wheels a shot, if they work, more power to you!! :)
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,079 Guests (See full list)
