PCM tune
Hi,
I was wondering if anyone would know of or had a PCM tune by this company that is local to me?
I was looking through a local Tri Ad Buy and Sell magazine and I came across this company called BR Power Source in Oakville Ontario that does PCM tunes while you wait. I gave them a call and talked to Burnie and he was very help full.
I asked Burnie all kinds of questions, I was waiting for him to cut me short as I was taking much of his time, but he answered every question in great detail. He said he just returned from out west as he was trained by one of the leading PCM tuner tech's.
His cost is $400 Cdn and he would custom tune my PCM from mild to wild if I want. The $400 would include an updated program flash as well. Any future up grades would be free of charge such as tire size changes and things like that.
He does Wester's tunes, he's an authorized dealer. $400.00 Can. is an excellent price, it's usually $400.00 US. I spoke to him last year, he seems very knowledgeable and pleasant to deal with.
Thanks for the information INDY. I would like to do a minor tune up (plugs & wires) and take my truck to the drag strip and see what times I could dial in before I got the PCM tune, then go back and see what difference a tune makes and post it in here, but I can't wait.
I think I will make an appointment to have the PCM tune done once the weather gets better out here, I have parked the truck for the winter and the PCM tune is one of those "I have to do it" modifications.
Well, tomorrow is the big day, I decided to go for the PCM tune at BR Power Source. 1st they will flash my PCM with the latest program, he will then see what is causing P0300 code as he seems to know what it is as it is a common fix. He will then custom tune the PCM.
I will post later what kind of difference I see in power and then fuel ecconomy a few weeks down the road.
Todd
I will post later what kind of difference I see in power and then fuel economy a few weeks down the road.
Todd
Goterdone!!!! All I can say is WOW! I can stop smiling. I am sure I am going to break something if I don't keep my foot out of it.....
Excellent :loser::banghead: I'm going to wait for spring and sell my Hypertech and drive down and get my mine done too.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
