2001 Yukon Denali
chemk
Can you tell me what would cause my rear air shock compressor to work intermittently.? :confused:
The compressor seems to be fine I took it out and tested it alone.
I have also checked all the connections, grounds and fuses.
:banghead:
Thank You
Pete Patera
I know that. But when I load it somtimes it does not work.
By load I mean an 18 ft trailer it should come on.
It actually takes very little to make it pump normaly but it only works somtimes.
Do you know where the sensor is. I have checked the ones on the frame over the rear end they seem fine but if I could get some values like how much voltage they are suposed to put out or resistsnce unpluged enything will help.
Thanks Pete
i do know that the fuction test consists of adding 400lbs to the back of the vehicle and waiting for the pump to activate,
not sure about resistance reading etc.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
