Electric Fans
If I put electric fans on my 2001 8.1, will I have to
get a new tune?
I've tried e-mailing Wester's but can't get through.
Do they have a new address?
Thanks
Bud
What is the best way to hook up electric fans?
quote name='builderpaul' date='Feb 1 2007, 12:35 AM' post='442120']
If you want the fans to be controlled by the PCM yes. If you used a seperate control than no.
Depends on the fans. Factory set up with the 2 fans best to operate with a tune. These come on at different temps and different speeds. If you are adding an aftermarket than use the connections that come with them.
I was getting a tune anyway so I had my pcm programmed for fans. Noticed only the 1500 come with the e-fans and was told the clutch fan, on our trucks, is better for max cooling under heavy load conditions. Never did put e-fans on my truck.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,253 Guests (See full list)
