Removing Radio
RCH
I got my 2007 Sierra a month ago and want to connect my MP3 player to it. I purchased the connector and harness from Crutchfield. I need to remove the the plastic around the radio, but I'm not sure if it is attatched with only clips or are there screws as well. Has anyone removed their radio and have tips.
Thanks.
Contact Crutchfield....not sure many folks have yanked their 2007 radio already...
Call best buy, circuit city and ask them.....they have the procedures...
typically you have to pull the dash trim to get at the screws to pull the radio...
be prepared for the radio theftlock to engage once you reconnect power to it.....might be ok since it get's the code from the BCM....
Theftlock is VIN controlled and un hooking the battery on any GM truck newer than 2003 is Vin driven. As long as the same radio stays with the same vehicle it came from your OK.
Wow, you can add an AUX port to a stock radio?
I wonder this because I see a button on the radio that says AUX, but could not locate an AUX port anywhere. This would make things really neat for my iPod.
How does one go about doing this? I don't mean to hijack your thread, but I figure since you are doing the task, you must know how it is accomplished.
I got the Aux. plug installed, looks and functions great. The trim around the radio/instruments just pops out. Removed all the screws for the bottom panel and it popped out as well. Radio had three screws and was out. unplugged 12 pin connector, plugged in GM12-AUXV2 that I purchased from Crutchfield(actually made by P.I.E. industries). Plugged original 12 pin into the new harness. Yellow wire to 12v constant(I used wire for lighter), black wire to ground. plugged in converter to new harness and mounted. This is where I customized it a bit, I didn't want to run it into the glove box. I wanted to plug into the dash, so I bought a cable that had the male RCA plugs on one end and a male 1/8 on the other. I cut the 1/8 male headphone jack and soldered a 1/8 female on instead. I bought a cable that had 1/8 male headphone jack on both ends, so when I'm not using the MP3 player the connection is almost flush with the dash. If you do this, be sure that after you cut off the 1/8 male jack that you run the cable through the hole before soldering the 1/8 female connector in place. To toggle between XM and AUX the instructions read to press seek forward twice and back twice, but I found that did not work. You press seek forward once and back once and it works. NOTE: Be VERY CAREFULL when removing the radio not to scratch the face plate for the heater control that is attatched under it. Maybe tape some cardboard or bubble wrap over to protect it.
You can purchase the 1/8 female headpone jack at radio shack.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,016 Guests (See full list)
