Clunk/Bump Noise
We own a 2002 GMC 2500 HD, extended cab, short bed, two wheel drive, 6.0 engine with 4.10 rear end. It has approx. 5,700 miles on it. We have started experiencing a slight clunk/bump noise when accelerating from a stop, especially when the truck is warm. Dealership pulled and greased the drive line and it reduced the severity, but it is still there. Have taken it to two dealerships and they still can't figure it out. Four wheel drive units have had a similar problem and it was resolved by replacing the yoke, but ours is a two wheel drive and no remedy for it yet. No tech bulletin on ours. Any help is appreciated.
Today, June 4, the truck is back in the shop.  They are checking the driveshaft again to see if it is aligned properly or if there is some other flaw.  Since removing it and greasing did decrease the severity, they figure we are in the right area, but we'll see.  Any other thoughts would be appreciated. The tech bulletin regarding replacing the yoke with a nickel plated one said it was for 2 WD & 4WD, but upon further questioning of GM, they said it was supposed to be only for 4WD.  We'll see.  Any other thoughts would be appreciated.  It only happens from a stop and when the truck is warmed up.  It seldom does it when it's cold.  Almost feels like we have something loose in the truck bed bumping against back of truck at start out, but that's not the case.  Thanks for all your input.
I thought the slip yoke problem affected any truck, not just 4x4's.
The new slip yoke is used on the rear drive shaft, not the front.
Just had a similiar problem fixed on my '02 3500 HD 4X4...do not know if this will apply to your truck or not but thought the info couldn't hurt!  On mine, during the break-in process, the rear springs have apparently settled to where they would bind slightly on take-off.  GM has some sort of service bulletin on this because my dealership ordered spring rubbers mentioned in that bulletin.  Took the springs a few days to re-settle after the rubbers were added and for the last 1,000 miles, the fix appears to have worked. :thumbs:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
