cluster replacement
<-------------------New guy!!!
I hope no one gets mad with all my questions. But i have another problem my speedo is out and tach. Now i know how to replace the steppers or even jsut purchase a new cluster. But what about the miles and the calibration. What else would i have to do besides plug and play.
You need to get the mileage and hours put into the new cluster (if you go that route). Most places wanted to charge me $300+ to do this but I found a guy (with a little help from another GM Truck forum guy) that only charged me $80. My new cluster came back in about 3 days with the exact mileage and hours from my old cluster. Now my truck has the trans temp guage and works great.
This guy also does complete repairs or just about anything else you might want. Great service and answered everyone of my e-mails quickly.
PM me for his info.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
