Washer Pump Source
Figures that I'm on the road in Wichita Falls Tx, miles away from home in NC and while driving through the storm on Saturday on I-40 just outside of Little Rock I went to use my washers and nothing. My wipers work but with further trouble shooting, what little I can do with no tools, I do not get any pump noise when I use the washer switch. I checked the fuse and it is good, fluid is full. The wipers work like they are suppose to but the pump doesn't work. So I'm guessing that it is bad.
Where is the best source for a new pump? This will be first on my list when I get home to fix. Once I will get home I can trouble shoot it better. Can it be the switch? When I turn the switch to activate the washer it turns on the wipers but no pump. I would think that if the wipers work then the pump should be getting juice as well, does that sound about right? I hate when this stuff happens with no tools on hand. :banghead:
I think all the major auto parts stores should have them. It was a pain to change it, but doable.
KRS
Please define "major pain" :thumbs:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
